good morning everyone, I am an installer based in Italy, I have done several installations with your products and I am very satisfied with every progress you are making. I personally own an opel speedster that I also use on the track to which I installed an emublack, adu7, switch to can and edl years ago, I would like to be able to import the wheel speeds into the data network, I can’t tell you what type of sensor the car has, I know that it only has two wires and is incorporated into the bearing, I would exclude a hall, my question is: is the adu able to read every type of abs sensor? if I connect it, can it not disturb my signal by disturbing the abs of the car?? excuse me if I ask here, when it would be enough to do some tests on the car, but unfortunately I am always very busy with work and the time available to me for tests is really limited.
I recommend reading through the user manual for the WheelSpeedToCAN module.
There is a description of different sensor types and how to identify and connect them.
It depends on the ABS setup if ADU can work with it in parallel. If the ABS module has a pull resistor on the high side, you won’t be able to read it with ADU.
Unless someone has already done it and will share the information, you must do some measurements yourself.
