Wireless racing kit
Salve, non riesco ad interpretare le istruzioni per saldare i fili per l’associazione trasmettitore e ricevitore sui PIN S1 S4 S5 S8 . E i PIN R1 S2 S3 S6 S7 per impostare il livello potenza segnale. Grazie!
To pair the transmitter with the receiver, you need to solder wires for four switches: S1, S4, S5, and S8. There is an example diagram in the manual showing how to connect the switches.
Without connecting the required switches, you will not be able to pair the transmitter with the receiver.
The signal strength is already set to the highest level, so there is no need to adjust it.
Could you please let me know what exactly you do not understand in the manual?
Per PIN “S” si intende i PIN SW ? E quindi il S1 con SW+ ?
Now I see that there is some inconsistency in the manual regarding switch pin naming — we will correct this.
S1 refers to switch 1, which should be soldered to pins SW1 and SW+, and so on.
Invece per quanto riguarda i PIN R1 ?
It has to be connected according to the diagram in the user manual.
Please ask your question in more detail so I can help you better.
Ok ci sono arrivato, R1 sta per Rotary switches, invece S2 S3 S6 S7 sono gli altri switches. Grazie mille, per l’aiuto!
