How do the paddle switch outputs vary from the 8 push button outputs?
Do they operate in the same manner?
They work the same way. Both are simple on/off inputs sent as single bits in the same CAN frame, so you can use them for anything you want.
Tacking onto this, when using the pre-built ECUmaster racing steering wheel panel, and the “ECM switch board” in the EMU Black, what are the paddles named?
I figure the coloured Otto buttons are the same as how they are numbered in the racing steering wheel panel manual, but what about the paddles?
Is it simply Left SW10, Right SW11?
