Apologies if this has been covered. Is it possible to wire two outputs to engage and disengage a 2 wire electronic e-brake without using external relays. Typically I wire them through a pair of NO/NC relays so when one wire is active (+12V) the other is ground. I would like to use two outputs but would need them to be NC to ground, there by when one output is active the circuit is complete. hope that makes sense. Then I could use some math inside the PMU for current overrides and time delays.
