112 teeth on flywheel
I have a Fiat Coupe (175) 1.8 16v 131hp, and I want to upgrade it with an ECUMaster EMU Black. My flywheel has 112 teeth, but I am unsure how to configure the ECU.
Can you help me?
Does it have a missing tooth or something?
Do you have cam sensor?
I’m not missing a tooth, I have a cam sensor, but I emailed tech support and they said the flywheel is not compatible with emu black master ecu
And now I think I found a flywheel that fits my engine with 125 teeth, but I still don’t know if the ecu can read that signal (it’s a VW Golf 4 1.6 16V AUS flywheel)
Why not mount an external sensor & universal trigger wheel?
Saves hassle and will work fine once configured correctly
Good Morning,
Unfortunately, the 112 or 125 trigger wheels are not supported by the EMU Black. There are modes dedicated to similar trigger wheels, but they require a distributor for correct ignition distribution. The best solution is to consider an aftermarket trigger, such as a 36-2.
Artur
Can you give me a concrete example of where I could buy aftermarket trigger ?
Yes, it’s a good idea but I don’t know where to buy external sensor & universal trigger wheel if you could put me I would be grateful!
Just google for EFI Trigger wheel set.
Multiple options here, you will still need to manufacture some way to mount the sensor.
