We need more than 32 operators for programming. Is it possible to upgrade to more? We need min.85 for that we want to do.
what are you trying to do?
We are programming a classic automatic gearbox and want to switch outputs for solenoids with addional terms. The custom pwm and DSG settings are not able to give us the options we need. The FNs are perfekt for that we want to do. Works perfekt, but is not enought to set everything​
Actually there is not enough memory to add more operators. But maybe additional operator would help ?
Good morning,
what do you have in mind when you say additional operator? We need to set min. 3 operators for shift up and 3 for shift down for every gear min. I made a lot thoughts and tryed to find out if we can do it another way with the options we have in your software. Ithink it´s not possible.
Best regards
Christian Wilms
Geschäftsführer/Inhaber
Das Triebwerk DTW GmbH
Eisenwerkstr.2
58332 Schwelm
Fon: 02336/4959456
Fax: 02336/4959457
Mobil: 0151/26436121
USt ID:DE307912976
Onestly, we want to use it only for that. Perhaps there is an option to erase other functions to have the space? We need only the anlaog in´s, the aux´s, VSS, trigger and tps. We need the Black, because we need the 6 Analog in´s. Let me know if we have a chance. Otherwise I have to decide other options this week. We have to hurry and to prepare a solution.
I think, i seen somewhere here, that FN are operated at 25hz speed, so will no be quick enought anyway?
By operator I mean function like Or, Hysteresis, Toggle, etc.
Also PhoB pointed important thing. The function evaluation period is 25Hz (40ms)
Yes we know about the speed. It´s no problem, we tested it. The delay is not an issue. We using or , hysterics as well. The problem is that every is one operator in count.
