Afterstart Delay (For Inputs/Outputs,etc)
Hello!
New to the community but not to the EMU Black. I wanted to know if there was a way to select a time delay for an input or output based on engine after start. Here is my application:
Upon initial start of the engine, I want to apply a time delay to the activation of the A/C clutch (maybe 2 or 3 seconds). This is different from the ‘Time to engage’ delay built into the A/C clutch output menu.
How can I achieve this? Is there a way to relate input/output activity to time after start?
U can use a function and use the option true delay. Then the respective variable (in this case maybe rpm) must be true for a specific time that the function shows true.
Thanks so much for this idea! In practice, this opens the floodgates for many conditional outputs. :+1:
