I think I am close to getting my SC300 with turbo addition started with EMU Classic - Need to ideas
I have a 95 SC300 with a turbo, R35 coils, and a cam/trigger kit. It runs pretty good with a stock MKIV manual ECU. I have been driving it in this configuration for a couple years.
I am wanting to start tuning and so am installing an EMU Classis. Starting with a ECU2JZ_2JZ-GTE_440cc_Startup_SEQinj_SEQcoils base map, I have it all wired up, have tested all outputs, IAT, CLT, MAP, TPS, VSS, added an external WBO controller, checked the timing (with fuel pump fuse removed) and all looks to be good.
I have added a relay for the fuel pump. It runs for a moment at key on as it should.
When I try to start the car, it starts for a moment and then dies.
Not sure if anyone can assist?
I have placed a very short video of me trying to start the car, the EMU project file and a couple graph and scope logs for two start attempts in this folder.
Thanks for any help you might offer.
Bruce
