Hi All,
I’ve just recently joined and i’m brand new to ECUMasters so i’m trying to learn as much as i can as i go. I’ve currently got an astra H vxr 2008 that i’ve been trying to get setup for months now. I’m experiencing a few issues and wondered if there’s anyone that would be kind enough to shed some light on how to get around them. My ecu is an EMU black v2 latest update.
# My first issue is during a cold start around 10 Degrees my RPM will sit at 1200rpm but will slowly start rising as it’s getting warmer i believe on logs it reached 1700rpm. I’m noticing if i blip the throttle rpm will come down and sit at targeted RPM.
# My 2nd issue is while trying to use my clutch i.e to park up the rpm drops to 500rpm and if i use my clutch any further engine wants to stall so i always need to give it slight throttle(which is very sensitive) to keep rpms from dropping.
My end goal is to get my car to around 300bhp and to be able to us it on the road but with these issues it’s driving me up the wall. I have tried to attach the software and logs but unfortunately as i’m a new user i’m getting blocked. I would greatly appreciate if someone could point me into the right direction. More than happy to make it worth your while.
Modifications:
Pre Cat delete
Sports CAT
3Inch Cobra CAT back
Airtec foam intake
MTC intercooler
MTC top hat
Forge Recirc valve
Turbosmart actuator
Hybrid KRS turbo rated to 320bhp
Everything else is stock (apart from brakes ofc)
Thanks,
