Audi s3 8l pnp emu black problem
HELLO , I HAVE AN AUDI S3 8L 1.8T BAM WITH 630 CC INJECTOR
When i start the engine was very rich , When i try to fix it whith ve map the car dont want go to higher rmp . its a big problem when i connect vacum on 400kpa Sensor to ,
I make Correction on injector cal
sometime car start but not good , only when the lambda is work
Sorry for my english
Thanks for help
Can you upload your map here ? change the file name to *.txt in the end.
Generally when Fuel is rich in cold start, you change water temperature correction, or afterstart correction. You change VE table only when you have no corrections from water or air or afterstart.
