AUDI TT ABS/ESP issue
Ive got my EMU Black BUB ECU running great in my TT, but have an issue with the ABS throwing a code.
            Address 03: ABS Brakes       Labels: 8J0-614-517.clb
Control Module Part Number: 8J0 614 517 HW: 8J0 614 517
Component and/or Version: ESP MK60E1 0130
Software Coding: 0017985
Work Shop Code: WSC 01236 785 00200
VCID: 6ADB77AF457FE0C375-803E
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 327817 km
Time Indication: 0
Date: 2025.03.21
Time: 10:39:49
It would appear the ABS system wants to save something to the ECU, but is not able to do so due to some sort of configuration issue that I have not done correctly.
Does anyone have a suggestion?
Cheers,
Ian
Change your DBW settings:
From 90% PPS and 100% PPS up to 3500 RPM, don’t use 100% throttle. Instead, make it progressive.
From 4000 RPM onwards, you can go to 100% throttle.
Hi Marcel,
I wasnt using 100% at WOT but did have 0 at 0. So ive changed that to 1% as per your dbw table. This is mine now…
When I use VCDS to clear the ABS error with the car running, it stays away until the engine is turned off. Then if ignition is turned on again, and the engine is not even started the ABS error comes back still.
This issue didnt happen till after I upgraded to V3 and had to build a map from scratch, so I am sure its something I have just overlooked.
Update.
Turned out to be engine protection settings. I was able to do a compare with an A3 R32 base map and discovered through trial and error that turning off all engine protection warnings somehow fixed the ESP/ABS issue.
Wierd.
These are the settings in question.
