Boost control Fuel flex + Rotary switch is it possible?
I am using flex fuel sensor and would like to use Rotary switch to control car power limiting the boost, lets say position-1 on switch is min power and position 8 is max power. Is it possible?
With EMU Black V3 it is possible to do flex fuel and a rotary switch.
With V2 you could use boost by gear for a rotary :wink:
Thanks for advice, looks like in v3 have to use same method.
You can use a rotary to blend between 2 tables and do correction with ethanol content.
also correction with:
CLT
IAT
VSS
EGT
GEAR
And you could do limit based on a lot of parameters
