3rd boost target/kill mode map
Currently have a base map setup for flex fuel and table blending for lambda and ignition.
The setup also has a meth injection system wired into activate on a switch. Using the custom correction tables I’m able to modify the fuelling and ignition timing to take advantage of the meth.
I am not seeing an option to be able to also Increase the boost above the normal second table. I had thought possible using a the meth switched input as a rotary input for boost blend and setting the second table to be the kill mode but the blend setting be 80%. Unfortunately it is only possibly to control ok the tables with flex or switch, not both.
Does anyone have any input or ideas on how this may be achievable?
