Boost PWM frequency change
Would it be possible for the devs to patch in the ability to send the PWM frequency of 1KHz for the boost output? I’m going to be running an EWG, but it has an external controller that accepts a PWM signal that would typically go to a mac valve. However they specify that that signal should be 1KHz.
The v3 only goes up to 400 Hz when set to PWM. and the only way to go to 1KHz is to set it to Electronic WG, but i don’t need that as the controller is the driver for the wastegate.
