Brake flasher logic. lower frequency needed on custom output channels
I want to add a brake flasher logic to my EMU Pro project.
I created a table based on longitudinal decelleration that flashes an AUX output that interrupts the voltage supply to the brake lights via relay.
The issue is the lowest I can go with the frequency is 16HZ which is too fast to be visible.
Of course I could use the on/off logic and add a flasher relay but maybe its not that big of a deal to lower the frequency in the software.
Regards,
Andreas
We have it planned to allow lower frequencies, but it actually is kind of a big deal. That’s why it’s not there yet.
Anyway, you should be able to use the “Flash” function from “Project tree” to achieve what you want.
