Hi all, I have my factory cluster CEL in my 1999 supra to wired to Aux 5 on my pro 8. For compliance with my local MOT inspection laws I have to have my CEL function as factory.
I would love to do this via a parametric output as in the black, but it seems the pro 8 does not support this yet. I only have the custom output option, but that doesnt have the functionality that I seek.
Just being able to link the output to an configurable RPM window or threshold would already help me out a ton. Any input on how to achieve this would be super appreciated
i am not sure if i understand ur problem right, but all u need for a decent CEL the EMU pro already offers:
U set up a function, which is true while engine rpm < xx or engine check light =1.
This function u use as an activation input for a custom output. In the custom output u then use high or lowside output, depending on how ur CEL in ur cluster works and then u have all u need.
Ofcourse! Thanks so much! Im so used and pampered with the black that I totally overlooked it. I just made the function and it works beautifully and gives me all the flexibillity I need.
Thanks for the pointer!
