Hello!
Trying to configure that my c2 vts 2005 stock dash shows vehicle speed and thus has odometer rolling. At the moment we see the vehicle speed at the ecumaster program (vss and speed vindow). See the current settings below. Can anyone help?
I think speed is on can bus on this car, so you need to select CAN correctly.
firstly on can set up - select citoren c2 and speed source CAN bus.
Thanks for reply @Greg. We are not using abs block for speed but this sensor at the gearbox and by spinning it we get the speed in ecumaster program in pc. Would the settings be the same then?
