Getting vehicle speed input to EMU Black
Hi guys,
How can I get the vehicle speed input in to the EMU? Can I do this via a ABS sensor ? Any other solutions?
My current setup: Aftermarket GPS speed sensor kit directly plugged in to the instrument cluster which is very unstable.
Application: Mitsubishi Lancer 2001 (4G15 Mivec Turbo & transmission from a Colt RalliArt)
Edit -
The car does not have a functioning ABS system. I have upgraded brakes from a FTO which came with ABS sensors but not being used for anything. So there is no concern about affecting the brake functionality. I just need to find a way to get the speedometer to work without relying on GPS.
I’m currently using a Dakota Digital GPS receiver that it feeding the VSS channel on the EMU Black. I had it feeding the cluster before getting the EMU so I just repurposed it.
If u have vehicle speed on CAN u can also input it from there.
Can I not keep it simple and plug the ABS sensor to EMU black and calibrate within the EMU ?
PS. The car does not have a functioning ABS system. I have upgraded brakes from a FTO which came with ABS sensors but not being used for anything. So there is no concern about affecting the brakes.
Is there a reason for using a “vehicle speed on CAN” instead of plugging it directly ?
If u dont have ABS u can use any wheelspeedsensor and plug it to emu…yes.
Thanks very much for the confirmation
Did this too. Directly from ABS sensor to ecu. Then calibrate speed reading from GPS.
yep, it worked eventually :smiley:
