i use calculated gearratio and it seems not to work:
2024_1011_1658_rev75_drive.emuprolog (2.0 MB)
AudiS5_CAUA_rev75.emupro (33.1 KB)
Calculated value matches the gear number, but unknown is displayed.
Is it a bug or do i do something wrong?
Ah okay makes sense. I also read that, but just was looking on the channel “clutch position state”, which is at 0 means clutch engaged. 2 is clutch disenaged. But u are right the channel clutch disengaged is active.
So both channels are kind of contradictory.
But probably it is cause my clutch position sensor is not set up correctly.
Will set it up sorrectly and check again…thx for ur help.
Update:
I setup the clutch now correctly and everything is working perfect now…thx ![]()
