Clutch position via CAN
Hi
i am useing a PRO8 and pull clutch position via CAN with following settings:
The CAN variable works fine, but the EMU seems not to accept the CAN value and the EMU clutch position always stays at 0 and the state is not calculated according the given borders:
Do i do something wrong or is this a bug?
Yes, it’s a bug. I confirmed it on the bench.
We will fix it for the next release. Thanks for the feedback.
In the meantime, you can use a custom voltage channel that works as intended. You can convert your clutch position to voltage in the project tree and convert it back in the sensor configuration.
