Can Keyboard flicker
Hi, after I’ve upgraded to the latest firmware my can keyboard brightness is misbehaving. I can see that it’s tracking the brightness of the ADU using the I inbuilt light sensor. The ADU reacts well to light changes but the keyboard is very erratic and looks terrible. I can’t see anywhere to change this within the software.
Cheers
Which CAN keyboard do you have, and which firmware version?
Could you share your project? I will check it.
Hi, I’ve got a RGB 4x2 keyboard with ADU firmware 121.0 and V3.055 black firmware.
20250908_0658_49.emub3 (68.4 KB)
20250907_2102_06.adu (67.5 KB)
I would suggest having brightness led settings based on total ambience rather than using it as a sliding scaling. Have 3-4 brightness callouts and use ambience in ranges. We run a high low only setting, based off ambience. Basically a day and night brightness.
The setting is in the keypad config, you have adu brightness selected and are using that scale for the keypad. Click “More Settings”
Perhaps try applying Joshua’s proposal. Otherwise, you can change the characteristics of ADU brightness, or create a separate number/table to control the keyboard brightness. Keep in mind that the keyboard brightness control is not as smooth as the display brightness.
