I’m having an issue I just finish one of my builds and Could not get it to run on V3 , but I did on V2 perfectly, I copy the trigger settings from V2 to V3 one by one and it wont start feels like is not firing on the correct order , I check base timing with timing light and it matches the timing gun
I did , but the result did not improved much still wont run and will back fire on intake, yet did does not happen on V2 that is the main concerned
Timing locked at 0* with timing light pulley at TDC and CAM sprocket verified at TDC as well the common trigger setting procedure , the only difference is even for some reason this is not working on V3
Can u post a log while starting?
I assume ur trigger settings are correct. Looking at ur fuel settings i assume u are flodding the engine. 30ms prime pulse is a lot. Ur VE seems not high but probably u take the VE from V2.
