Control of analog input via Ground
it is about indicate direction analog input. LED indicator.
The analog input is up to 5V, so I converted information from the direction indicator to Ground. I did not want to let go of 12V. Unfortunately, the LED now lights up permanently and flashes only when the direction change indicator is switched on. Can you make some adjustment in the settings or I convert everything to 5V?
Thanks for the information
Already resolved with the help of a digital input :see_no_evil: :grinning:
FYI for things like High beam, indicators etc the pins Analog Inputs are 12V tolerant so you can just feed in the 12V signal and then make the settings something like above 4V = on and below 3.9V is off. Makes life much simpler, unfortunately the manual doesn’t tell you the pins are 12V tolerant (only measure 0-5V) I had to email tech team to find out if the pins could handle 12V
That is good information. I’m sure it will help others :+1:
