Couple of tuning issues
It worked I got a log. Its rich at startup than slowly it clears up. Il send log when iam home
cold start runs fine2.0.emub3 (66.9 KB)
think just lower the ASE table a bit and should be fine.
14080814.BG3 (7.6 MB)
First please update to latest version to have latest fixes.
https://www.ecumaster.com/testVersions.html
Then please try this calibration
cold start runs fine2.0_moded.emub3 (67.5 KB)
  1. I modded you a bit the ASE table
  2. I nulified ASE and warmup table 2 to not create the false impression that those are used
  3. Increased a bit the values in the Airflow table for the 1600-1200 rpm since in the log it clearly can’t keep up with the required target. You can add more once you create a new log.
At least now you have a clear understanding what to touch in order to do your own changes and log the result.
still working on the ASE table its still way to rich at the beginning and iam working on fixing that. when i got this good i will send another log with tune.
