Data master not showing correct TPS. Both EMU and graph log in ADU show 100% TPS and can be confirmed from the throttle plate angle. DBW Pos and voltage also indicate this in EMU and ADU. In DATA MASTER maximum TPS recorded is 80% consistent throughout all sessions. Has anyone else experienced this?
This might be a bug, please send the affected log file.
What is the best way to send the log file to you?
You can attach it here or send it to michal.kowalski@ecumaster.com
Thank you, Email sent
Thanks for sending the file. I checked it in both versions 2025.4.2 and 2025.4.1.
The log appears identical in both Data Master and the ADU software.
The TPS reaches 100% several times up until the 6-minute mark. After that, the maximum value I see is around 93% at 20:32.280.
I have sent a screen shot of my DM Screen. I do not show 100%
