Hi all , can someone give me a sanity check , DBW gone through calibration tool , TPS and second PPS calibrated and working correctly , i cannot for the life of me get the throttle plate to move using the pedal ,
Just sorted it , gear scale was set to 0
was about to say the “disable when no rpm” box is checked, but you didn’t say if this was engine off or running.
yes it was with engine cranking and off , turned out to be the Gear tables in DBW were set to 0 , sorted now but thanks for the input..
