The throttle calibration works perfectly, TPS values are normal with no fluctuations, but there’s no response when I press the gas pedal.
Please follow post creation rules:
- Describe the issue you’re experiencing in detail.
- Attach your project file and a log or scope file that shows the issue.
- If you can’t upload files here, use a file sharing service like WeTransfer and paste the link in
your post.
dbw calibration has been performed, there is no imbalance in the voltages, tps calibration has been performed, there is no problem with the voltages, but there is no reaction when I press the gas, even though it is buzzing from the dbw. When I press the gas pedal, although the gas position changes between 0-100, there is no change in DBW.
20260217_1842.emublog (1.7 MB)
log
Absolutely correct observation, thank you very much. I hadn’t noticed; I remembered it being generated automatically.
