DBW wiring and CTS wiring
I have 2005 Subaru non turbo with DBW comparing factory pin out , Drive motor I have figured out but I’m getting lost hooking pedal position sensor up and
I have factory coolant temp 3 wire will signal wire to gauge work or should I switch to a GM two wire sensor any help greatly appreciated. Also sensor ground can that be spliced packed ?
