V3.044 DBW setup
Hello!
I updated to 3.044 yesterday. I started as sugested here, with a blank project. Setting up everything from scratch. Everything worked fine! V3 is great. But i can’t seem to find how to assign Pot1 and Pot2 for DBW.
I use a tps on the oem pedal, on V2 firmware that was assigned as TPS. But if i understand it right that signal now should be PPS? And pot1 and 2 from dbw is TPS?
It’s described here.
Hey guys,
My DBW calibration Tool dont work.
Ford MK2 rs
20250310_0644.emublog3 (500.0 KB)
jan V3.emub3 (62.9 KB)
Analog 1+2 are the DBW inputs
I hope somebody can help me
Your sensor assignment is off. Throttle position sensors are assigned to pedal position sensor.
You should have ain 1 and ain 2 assigned in TPS setup, and TPS main signal input in PPS setup. Can be confusing.
