Dq500 configuration
Hi guys!
Just installed a DQ500 on my golf V r32 and with ecublack pnp BUB version.
I wanted to know if someone can help me to configure the dq500 on my ecu please.
I’m using the oem dash and all the can network is oem. Before I had the HTG for the gearbox but I have removed it and reprogrammed the mechatronic. Only thing now is I also need to wire the dq500 plug which has can high and can low. Thanks for your help
i think you can beter post youre question in the emu classis/black page.
the canbus is like this if you want to use the aditional connector for it.
