DQ500 from a 2016 Audi Q3 2.0 TSI is supported by Ecumaster Black?
I use a Halltech GPS input into the Emublack vss input on a dq250 box. Click on emulate and etc in the V3 software. It works nice so far.
Mines in an MR2 roadster based kit car
yes, it possible. 0DL gearbox with speed sensor and mech from 0bh
I can confirm the gearbox in the Topic is indeed Pq35 and works with Ecumaster.
However as @ANDREI mentioned it does not have a input speed sensor in it from factory, and this causes the Basic settings adaptations to fail. I tried multiple options for adaptation and still cant get it to finish.
I’ve got an error for the missing engine speed signal. That error appears only when engine is started and there are RPMs.
I will try to add the missing sensor as mentioned by ANDREI above and will trey basic settings once again. Btw car runs fine (apart from bite point, in D it tries to pull the car hard in front so adaptations are needed).
I can confirm that this sensor should be there in the DQ500 gearbox (even if not installed from factory) in order to be able to pass the basic settings. I did installed it and the 2 error codes that where there in the DQ500 disappeared and the Basic Settings got successfuly finished.
All the credits to @ANDREI
