V3 and Dq500 - is anyone running it successfully?
Hi everyone,
is there anyone running DQ500 with V3 successfully? If so, which version are you running?
Would be great if you can share your feedback on this topic.
Thank you ; )
I would say solo or andrei are the ones to talk to. See this post.
If you using DQ500 in the OEM car, please use 3.066 version as in the previous versions the ECU always sent Gateway messages to the CAN
No it will be a 1.8T 20v project running dq500 from rs3 with diesel TCU.
When you say ‘‘Gateway messages’’ what exactly is being sent here? What information is this from EMU to the TCU?
If the DQ500 was selected the messages normally send by gateway where always send (even when gateway emulation was disabled). So if you have a gateway module it cause the issue on the bus.
@ANDREI did you also need VSS input beside the speed sensor on the gearbox?
Yes VSS input is mandatory into the ECU because it is reported to gearbox over CAN and the DQ500 has the shift points based on the VSS (Speed)
Thanks a lot Andrei! I see your running your DSG on V3. How is the DSG control working for you on V3?
I moved to Maxxecu. Maxx more comfortable and and closer to the stock ECU
Ok fine! In the time you were running EMU Black with V3, was the DSG control good? Were you happy with it?
I wasn’t happy with how the DQ500 worked on the Emaster, so I switched to the Maxxecu.
@xsd have a look here on the experiences.
I don’t have a DQ500 but a fully build R32 turbo on DQ250 stage4 with clutches on the latest version V3 on emu black and drives like OEM.
Yeah, I also did one this year. DQ250 has a different operating logic and does not relly on VSS.
