I use ecumaster black in my vehicle and I want to make dual maps.
I want to make two maps as a race map and a safe mode.
How should I proceed in the wiring and software section of this?
I couldn’t see a section about the second map in the software.
simply use a switch or analog input to switch the map. 12v on ain or switch1-3 to ground and select the input for map switch and you are fine.
