Map sensor assign on the software
Hi
Can someone assist me with map sensor assign on the Ecumaster black plug and play for the bub. I fitted the plug and play. And added the map sensor.
But the thing now is… where do I allocate it in the Ecumaster black software?
Regards
Jeff
On the tree on the left side when you open the software:
Sensors setup > MAP, BARO > Parameters
Thank you. I found that yes.
So by the sensors setup I added a picture.
By the map analog input: from 1 to 6 which one will be the correct one. If I wired the map sensor to ecu terminal 9 like it states on the input/output plug.
Ahh now with more context I understand.
I believe with this unit its the check box for the built in MAP sensor. the Black has a map sensor built into it’s board via a vacuum port and the BUB PNP units don’t have one inside the case.
That check box is enabled in the base map for this PNP.
