Hello
I have installed the ECU Master app and I connect via Bluetooth (either as Bluetooth device via Bluetooth scanner in my mobile phone is only from the app itself)
Both ways doing the same problem.
It connects for 2-3 seconds and disconnect again. And this is a continuous situation. Connect and disconnect with 2-3 second in between tame elapsed.
I have a Xiaomi 11T phone
If I just connect from my phone Bluetooth scan it stays connected.
Problem is in the app.
Please help
First, please don’t pair the device in your phone’s Bluetooth settings. If it is already paired there, remove it (Forget / Unpair). The correct way to connect is only from inside the eDash app.
This kind of connection loop usually happens when the communication settings in the EMU are not configured correctly. To tell you what to set in the EMU, I need a few details:
- your EMU model and firmware version
- the Bluetooth device you use to connect (EDL-1, BT Module or BT to CAN)
Once I have this information, I’ll send you the correct settings.
Thanks for your message.
I will send you these information as soon as my programmer answers me these you asked.
Hello
It was a adjustment in the ECU Master software
