Emu black v3 software informations
any updates on the classic adaption? thx
There is a slight delay with official releasing V3 due to v2 importer and help. As soon as we released it officially we start to work further on classic version
Will the classic get more dashboard can bus protocols in the drop down? Using can bus module?
@Jadzwin_ECUMASTER any info?
there should be most of emu black streams available. of course with some limitations due to classic limitations.
Any plans on adding an extra set of boost tables?
In applications of compound turbo setup this would enable precise control of the first turbo stage. The PWM table is not ideal for controlling wastegates.
It would be nice, if in new firmware for Classic:
  1. we could use as switches: -secondary trigger(cam1), -VSS, -Rx
  2. use unused ignition outputs for other functions
  3. maybe use unused knock/egt/wbovs for extra frequency/analog channel?
@Jadzwin_ECUMASTER Is there any instruction how to update from v2 to v3 software? Not just the update but also adjusting the values?
Any Update on V3 for Classic ?
Any update with V3 for classic?
The v3 will be relesed 13th November.
I hope the beta version for volunteers will be available in 3-4 months after that
  1. isn’t possible because of the embedded system. Don’t believe #1 is possible either,
    to add to this though:
    • IAT vs Idle DC. I would love this feature im sure many others would as well, considered switching to black many times just for this 1 feature.
    • Idle DC adjust it for an RPM range like in black
    • Ability to change when an analog input is considered active. Clutch switch for example, I should have the ability to say hey if its over 1V I want it to be considered active.
IAT vs Idle DC → There is a custom correction 3D table where you can apply IAT correction.
Idle DC adjust it for an RPM range like in black → Could you explain what you mean ?
Ability to change when an analog input is considered active. Clutch switch for example → Use function for that
IAT vs Idle DC, There is a 2D analog in correction table, which would require running 2 IAT sensors or splicing the wire to an analog port, and the classic doesn’t have many analog ports so thats not very viable. There is no custom correction 3d table.
Idle DC adjustment table. The black uses a 3D table for the Idle ref DC while the classic uses a 2D table.
These are just things I would like for the EMU Classic, seems like you think I’m talking about the V3 software for the black.
Now I understand. I was thinking you are talking about V3,
The V3 for classic will be exactly the same as for Black with some limitation (like less analog inputs, limited CAN and DBW due to hardware limitation).
There will be one software for both ECUs and the projects will be compatible.
Awesome I’m so excited!
Any update on when it will become available for the classic?
Anything yet ?? Any updates by chance ?
The Beta V3 for classic is already available:
https://community.ecumaster.com/t/how-to-upgrade-read-first/5689/2
