There is a new software version with new features and bug fixes.
This version includes beta firmware for EMU CLASSIC with CAN BUS support (more info in post below). Also the rev limiter has been hysteresis was implemented (see the short video how parameters changes the exhoust sound at rev limit).
Updated firmware for Classic (3.066.01). Fixed Analog 3 input readings.
More information can be found in the change log.
https://www.ecumaster.com/files/EMU_BLACK_V3/V3StudioSetup_3_066.exe
EDL firmware 1.27 → EDL 1.27
Change log file: https://www.ecumaster.com/files/EMU_BLACK_V3/changeLogV3.pdf
Short video with different rev limiters settings
CHANGE LOG
Client:
• Separate configuration files are now maintained for EMU BLACK and EMU CLASSIC ECUs.
• Fixed Scope window refresh issues.
• Fixed parameter range (0–16000 RPM) in function operator Hysteresis.
• DSG-related options have been removed from EMU CLASSIC.
• Fixed an issue where assigning a single ignition output to multiple cylinders generated an unnecessary warning message.
• EMU Classic options are no longer visible in EMU Black projects.
• EMU Classic Ultratech variant is now properly detected.
• Ignition Outputs 4, 5 and Analog Outputs 1–4 now display correct pin descriptions in the parameter list when EMU Classic is selected.
CAN BUS:
• Added support for EMU CLASSIC CAN BUS Module.
• Added CAN output support for Nitrous outputs.
• EGT2CAN reception can now be disabled.
• CAN Input IDs reserved by internal strategies (e.g. OBD, EGT2CAN, TurboLamik TCU, etc.) can now be used by User CAN when the corresponding strategy is disabled.
• MK60 ABS/DSC initialization frame (CAN ID 0x610) is now transmitted in BMW E46 and MINI CAN streams.
• Fixed CAN brake switch reception for Ford Focus RS/ST CAN stream.
• Fixed an issue where MPX data could be transmitted even when MPX support was disabled.
• CAN stream for 3rd-generation Suzuki Swift has been updated.
• DSG DQ500 Gateway messages are now properly disabled when Gateway Emulation is disabled.
FUELING:
• Extended lambda sensor measurement range from λ 1.89 to λ 2.50.
• Extended Lambda Target Table range to λ 2.50.
• “Disable Fuel Delivery” now also disables Prime Pulse.
REV LIMITERS:
• Added RPM hysteresis parameter for Rev Limiter and Launch Control strategies, allowing users to create different exhaust sound characteristics during limiter operation.
• Rev Limiter Fuel Correction now supports both enrichment and leaning of the air-fuel mixture.
OTHER:
• VSS is now displayed correctly on eDash when using the BT CAN Module.
