Version 3.063 BETA
New version of EMU V3 software is available with many new features and improvements!
https://www.ecumaster.com/files/EMU_BLACK_V3/EMUBlackV3Setup_3_063.exe
New EDL firmware ver 1.23 available (1.21 is required for V3 firmware in version 3.051 and higher)[https://www.ecumaster.com/files/EDL/VERSION_1_23.zip ], with better SD card support, added support for Lexar sd cards and improved bluetooth communication.
Change log file: changeLog.pdf
Gearshift:
  • TurboLamik TCU Rx and Tx default CAN IDs updated
  • Fixed TurboLamik TCU torque reduction issue
  • Upshift timeout increased to 1500 ms
DSG:
  • DSG paddle shift automatic upshifts implemented
DBW
  • DBW Characteristic 2 flag is now correctly set when no characteristic switch or blend is active
Rev limiters
  • Rev limiter spark cut now supports fuel enrichment for enhanced pops and bangs
Other
  • Added option for battery voltage filtering
  • ALS can now use Idle PWM and 3-wire PWM solenoid during operation
  • Added Invert Output option for PWM #1
  • Added Invert Output option for PWM #2
  • Prime pulse time extended up to 100 ms
CAN Streams
  • Fixed Ford Focus RS/ST CAN stream (ABS)
  • Improved Mazda MX-5 NC CAN stream (ABS)
Windows client:
  • Windows layout is now saved correctly when Launch Control and Rolling Start boost target windows are placed on different desktops
  • Restored Snap to window option in General Options
  • General Options: devices.xml file can now be saved either to the Default or User data directory
  • Copy/paste support for tables compatible with Microsoft Excel and OpenOffice Calc
  • Firmware upgrade process now correctly displays the subversion number
  • Fixed issue where Duty Cycle Correction X-axis bins reverted to default values
  • Fixed crash when exporting logs to CSV if the selection was shorter than 200 samples
  • Fixed IAT boost correction Y-axis description
I got my Battery VOltage Filtering ! Yeah baby :slight_smile:
:victory_hand:
So in the section ‘‘fuel correction’’, 0 means no correction at all, right?
You may want to read this https://ecumaster.com/files/EMU_BLACK/EMU_BLACK_Migration_Guide_to_V3_Software.pdf
Corrections In V2 software, for most correction tables, a value of 100% indicated no correction. However, in
V3 software, this has been unified with the EMU PRO concept, where 0% denotes no correction.
Warning: This is a very common mistake made by users transitioning from V2 to V3.
Excellent! Copy paste from excel ? THANK YOU :smiley:
Life is again easyer !
When we can expect the password protecrion for calibration file ?
ABS light extinguished, ABS operational on 2009 NC2 Non-DSC model.
Speedometer is still inoperative.
Thank you Jakub
Interpolation of ignition table in alpha-n mode while changing y axis tps set points is still not working.Its giving me headaches
I’ve just tested and I confirm it doesnt work. I will fix it ASAP.
Here is a link to the fixed windows client installation. What is interresting this bug is also present in V2 version…
BLACK V3 3.063b
Amazing new features! Absolutely love it on EMU Black! Still hopeful for EMU Classic. Any updated timelines? @Jadzwin_ECUMASTER keep up the good work!
We are testing the classic firmware right now.
Some stuff need to be added ro client and there is CAN bus support missing.
But we are going forward fast with the classic firmware.
Will you make 2stages of nitrous on classic as well ?
v3 for classic will be exactly rhe same as for black.
The only difference will be in CAN support.
Updated and tested this version this evening.
DBW Blend issue continues to be taken from the wrong table.
See Screenshot.
DBW1 Table set to 50%
DBW2 Table left as normal (100% TPS for this test)
DBW Blend shown on the right at 100%
DBW target shown at 50%
This shows that when the blend = 100% the target in taken from DBW1 table not DBW2 table as stated in the documentation on the right hand side
It is somethibg wrong with the help.
100% means the targer is taken from Table #1
I will check the help
Thanks for clarifying. However the help menu appears to be a more logical set up than you have suggested above.
0% blend being DBW1 table. As it would be when blend isn’t set up, as DBW1 table is the default, then 100% blend from DBW2.
I confirm that the information in help is incorrect; however, the equation fromthe help is correct:
The default blend table looks like that.
Why there is no async accel enrichment happend on this picture please?
This implementation is great! Any chance adding by speed (not only rpm) and possible speed of rear/front wheels only? :smiley:
