Flex fuel ignition
I’m struggling to figure out flex fuel for ignition. Is there a setting to do a second ignition map for content? I see the scale for fuel.
Use the custom correction. You can edit the axis’ to be whatever parameters you want. Flex % and CLT for example
I think I got it. I was able to make the map 4d and use eth content for Z axis. Still need to test.
