SamiN
November 12, 2024, 2:52pm
1
When generating pinout (using FW 106.1), it shows only 8 message objects (I have 12).
It would be nice if it lists all objects used in project, as it helps you keeping track of used can addresses.
I thinks it´s same at PMU too.
Thanks for reporting this issue. We’ve added it to our backlog. Ii will be fixed in one of the future release.
A new firmware version 106.2 has been released, where pinout generation is fixed.
We’re pleased to announce the release of the new experimental ADU software version 106.2-exp! This update brings improvements and fixes.
Improvements:
Improved brightness handling for Shift Lights LED and User Lights LED for low brightness levels
Slightly reduced memory consumption
The number of maximum CAN User MOBs in the generated pinout has been increased from 8 to 50
For full details, check out the changelog. Download ADU software version 106.2-exp today!
https://www.ecumaster.com/test…
