Hi, is it in plans to rise amount of canbus inputs elements? Im preparing 24DL to be logger of an older Motec ecu, gpstocan unit and maybe something else, but im already eats up all 150 inputs…
How many Canbus Input elements do you need?
I dont know exactly. As example, when i would try to define the single 8bit message of DTCs or some status data to 8x individual messages, it counts up quickly.
I see on ADU is enumeration function, which can helps a bit, but its also amount limited.
Or maybe there is some more memory effective way?
