Need some help with wiring and setup, some trigger info, some info how to wire transmission position sensor to outupt gears etc. Also pneumatic shifter will be used, with button, but it uses 12v, can it be wired to cut while shift and whats the best way?
do you have a emu black?
Yes black. Wiring of shifter sorted. Gear sensor also wired. If someone can help with something will be great.
gearbox sensor is under the table sensor setup, vss and gearbox.
for the shifter you need a sensor and you can setup in gear cut under the table sport.
