Hi all,
i have paddles which switches over ground signal, can i split the wire for shiftingsystem to my pro and use this for the cut? i have also a gearpoti in the car.
Hi all,
Yes, you can.
Is it a sequential gearbox?
Why not control it directly from PRO?
Hi Marek,
This is the next step, if all other stuff is working proberly. The thing ehy i ask is, i find only setup for loadcell and i dont have the space for a loadcell.
Thx
Wire two switches as voltage divider and you have output hi and low depending direction. Exactly like load cell
Use the switch inputs for paddles.
The shift procedure starts when you use the paddle and activation conditions are met. The strategy will go through all the stages to perform the shift.
The progress of the strategy can be checked by looking at the “Gear shift State” channel. It will show any errors and the progress of the shift procedure.
The pre-shift stage is used to remove the current gear. You need to reduce (cut) or increase (blip) the engine’s torque so there is no load on the gears.
The shift stage is used to insert the new gear. You have to reduce (cut) or increase (blip) the engine’s torque to match the engine speed for the new gear.
The post-shift stage is used to make sure the new gear is in with constant delay before the torque recovery.
Torque reduction is the general value from 0 to 100%. Depending on the reduction percent value, you must configure what reduction method should be applied. The most basic setup uses a 0-100% cylinder cut for 0-100% torque reduction.
Hi Marek if i use now loadcell for shifting i have also all procedures for shifting or are there only shift?
thanks
The input for the shift doesn’t matter.
The shifting procedure will be executed the same way with all the stages.
ok thanks i will try it this weekend Marek
