Help needed V3 Logging on Startup
Hello all ,appreciate the support new to EMU BLACK V3.
** First is there a TRAINING OR Operator manual for V3 ?
Having few issues with slow week start . Can I ask for little direction on how to do the following ?
** Log Cranking information . Crank fuel compared to AFR to figure out what the ecu is asking for . Found fuel tab but thought there would be one for crank fuel because of v3 tabs layout .
Also need to start log pre cranking AT 0 RPM . Think I found this one right click RPM SET 0 ?
Can you log prime Pulse ? input while cranking . Could not find in log .
State of Start up log ?
These values I’m sure are there just not sure how to log them so I can compare .
Thank you !
Anyone help please ?
In the application there is a help for each strategy.
The prime pulse time is only visible on the Scope.
Unfortunatelly I dont understand other questions.
