Holley Pro Dash and EMU pro 8?
Has anyone used a Holley Pro Dash with the EMU Pro 8? I’m working on a truck that we recently decided to switch from a Holley Terminator X system to an EMU Pro 8 and PMU 24DL. We are trying to keep the Holley Pro Dash and send all the sensor data over the CAN bus. Do I need a Racepack interface module? And a racepack pro dash?
We have been doing that with a CAN router. I know floating point was going to be added to ECUM line, then you could technically do it without the router but at the cost of resources.
Instagram
What CAN router did you use for this?
We get ours from Minton. You’ll need to write the code for it and figure out all the CAN qualifier Holley has put in so it thinks there is an ECU.
Is your program something you would be willing to sell?
Yessir, we can help if need be.
I see ECUM is releasing a 2 channel CAN router type device at SEMA. If it can do floating point, you would be golden.
