How do you set up a voltage over SENT channel from a digital input?
Working on my EMU Pro 16 on my bench and I’ve got my throttle body sitting here (87mm off of a ‘17 Z06 Corvette). I pulled up the AllData on this one and the TPS is SENT1. I’ve got it pinned to Digital 2 on connector A13. I cannot for the life of me figure out how to assign this one.
In the DBW section it gives me an option for ‘Voltage of SENT’ and then I can pick SENT-14 and Channel A/B for them but have clicked around everywhere I can figure out to assign it. I enabled SENT 1+2 under Communications.
Help?
AFAIK SENT decoder is only available via DI module and not the PRO directly
As mentioned, the SENT protocol is supported only through the GDI Driver.
