Logging data in PMU24DL
Hi, I was thinking of adding 4 suspension travel sensors into my build plan. The only place i have 4 spare analog inputs is into a PMU24DL. Would there be any issue logging these at 500hz in the PMU and syncing the data with ADU logs in Datamaster?
Unfortunately, there is no way of loading data from two devices at the same time.
What would you suggest is the best way to do this?
I could move 2 fuel level sensors, gearbox temp and oil accumulator pressure to the pmu and send that via CAN to the ADU. Then wire the suspension travel directly to the ADU.
That’s a good idea. I don’t know the details of your setup, but that’s seems easy enough to do and will enable you to log the suspension travel directly in the ADU.
