Hey, Im wondering if its possible to get this abs unit to be read by ecumaster black to get the wheelspeed sensors , for wheelspeed,traction controll etc? anyone that have done this and can help? i know for a fact that maxxecu have this figured out already but dont want to change my ecu.
I saw that mk60e1/e5 was supported in v3 now, it worked so guess i just need to remap the car or are you planing on releasing this to v2? ![]()
This is not actually a question about ABS, but about the vehicle CAN.
The Bosch MK60, used in OEM applications, does not have a standard CAN stream.
The CAN stream that comes from that module depends on the car itself.
There is a Bosch MK60 race version that has its own standard CAN stream. That is what is implemented in EMU when you select the Bosch ABS.
To read OEM ABS data, it must be implemented as part of the vehicle’s CAN stream.
So the question is, what car are we talking about?
I tried the v3 canbus stream for mk60e1/e5 in my bmw e81 that normaly is a 4cyl that have mk60e1 but have it swaped for a mk60e5 for my e9x m3 front/rear suspension and i got all 4wheels speed into the ecu
i guess we will just have to get the car remaped on v3 later this year
will you implement that mk60e1/e5 in v2 or do i need to change for v3 program?
What settings are you using on black to read from the wheels?
I have put the mk60e5 protocol, but no wheel speeds are readed. On adu and cantcu I can read them no problem.
the settings I’m refering are the driven axle, non driven axle, vehicle speed and wheels setup.
ive only tried with v3 program to se if it works and there i get all wheelspeed signals in to the ecu, but i cant use that now since im mapped on v2 and havent had time or money to change yet.
did you use bmw e90 can stream on the options menu?
So far I have put the 0x00CE adress. the same as oem MK60E5. but on black nothing appear.
I’m using ADU 5 to transmit the can mensage from can 2 to 1. using this method I can change the speed from 500kbps to 1mbps. on cantcu it appear correct but not on black.
I gonna try again other settings
Yep using e90 canbus stream
Is your car a bmw e90?
I tried today only with mk60e5 option enable. It reads now but had to put ratio around 20.
If you select the e90 canstream on the options will it mess with other canbus stream, custom one made by us for example?
Hm i dont know, i dont know how to make my own can streams😅 i use the e90 on my e81 1series to get my dash to work, would love to have steering wheels Buttons and stuff to work also😂 im using v2 program at this point but if i put it on v3 the wheelspeed signals work
It’s working for me at the moment with current settings. probably have to adjust a little bit here and there to get it to the point but for now perfect with only mk60e5 settings enabled.
Possible to send my settinga if you use v2? ![]()
