for evo it is not poaaible to work in wasted spark only using crank pattern as it is multitooth.
You need to use both cam and ckp and wait until the engine sync
Hello.
I own lancia 2.0 16v whit 1342
Trigger is 60-2 whit 79 degree
Only cam trigger
Using 2 dual oils.. One for cyl 1-4 and one for cyl 2-3
May you please help me get it running, it always drowns in fuel and bangs into exhaust.. Trigger setting is okay, it’s phase and degree and all that
Hey Matthew,
I am having the same issue with V2 on my eco 8 with PNP adapter, bypassed the Junk PNP coil wiring directly from oem harness to EMU, still no luck getting any sparks. Do you mind sharing your setting on ignition and triggers? Jeremy hasn’t about to figure it out yet, on stock ecu it will start up and run on first try, we haven’t able to get it running on emu. I had double checked the timing, cam angle, good fuel pressure, new plugs and had tried just about all the firing order/injection phrase you listed and Jeremy tried, No spark at all still.
TIA
Matt C
