On the log there is an option to log “Idle Air %”, would it be possible to also get “Idle Air % Target”?
Just as an example I founfd some coldstart from last year.
It was done on FW_3.038 in -3°C
Battery dropped to 9.7V (never was problem to go lower).
As you can see, its clearly visible each turn of engine during cranking on battery voltage the same as on MAP signal.
Also labda have no problem to be stable.
It was newer the issue during cranking. In PC version also in EDL.
I really cannot reproduce your issue. All is logged, cranking is nothing that can influence the logging (except voltage drop belov 6V)
Other option you have the boundled firware with edl logging issue. Then it require pc connection to start edl logging
Hi, is there a possibility that we can get user functions that can manipulate whole tables.
For example: if the condition in the function is met, multiply the whole airflow ve correction table by 1.1.
Or is it already possible and i don’t know how?
It’s already possible. Arithmetic operators can be applied to selected cells by entering a value followed by an operator.
For example:
• Enter 5+ to add 5 to the selected cells.
• Enter 0.5* to scale down the selected cells by 50%.
Available operators: +, −, *, /, %
Dear Jakub,
I have to apologize, customer came with the car and I foud completly loosen battery terminal.
The “issue” is solved.
- No PC log issue
- No EDL issue
- No Lambda issue
Sorry to disturbing you from more important work, thank you for hint!
You can activate a custom fuel corection with fn. Then you have a table for ve or lamda target modification
Under outputs on 57 when using the quick tabs at the top . I can choose fuel pump parameters and when I return or restart it always says (electric Water pump ) parameters.. may be a bug .
Why is there always a map error in the logbook for no reason?
It is not possible due to the system architecture.
Already fixed for version 3.058
Already fixed for 3.058
Already changed to 500 in 3.058
Now there are 3 3D custom tables for ingition corrections.
It gives you much more freedom.
